DVDFab DVD Copy can copy and backup DVD to computer/PC/HDD if you don’t want to copy it to a disc. DVD Copy can output DVD folder or DVD ISO image file for backup on the hard drive of your PC. This kind of DVD backup can be easily done with just a couple of steps as follows:
Step 1: Start up DVDFab DVD Copy, load in the source
Start up DVDFab 9, and choose Copy option. You can see 6 copy modes in the main interface, just choose one. We’re using Main Movie for example. Then insert the DVD disc into optical drive and seconds later the source DVD movie will be in with the longest movie title auto selected and audio tracks and subtitles changeable. In the lower part, for the Output, please choose DVD 5 or DVD 9 accordingly; for the Save to, please click folder icon to choose a directory on your hard drive for saving the output. OK. Click Next button now.
Copying dvd to harddrive:
Step 2: Start copy process
Now preview the title in real time and check if everything is alright. Then hit Start button on the main interface to start copy.
During the whole process, you can view detailed progress info and preview the progress with real time images.
OK. Soon, everything will be done. For more info about DVDFab DVD Copy and what else it can do, please go to: https://www.dvdfab.cn/dvd-copy.htm
